Best header gaskets?
Old Feb 16, 2012 | 07:49 PM
derekguzz's Avatar
derekguzz
Default Best header gaskets?
I have had my hooker long tubes on my 94 for over 4 years now I I cant remember a time where they didn't leak. I am interested in the shiney aluminum ones from lets say autozone or something? They are double thick.
I am tired of having exhaust gases in my engine bay, louder noise in there too, burnt gases on my valve covers, and or course the xtra heat if I don't need it. Has anyone ever fixed this issue I am having? I have had 3 different gaskets over the last 4 years, all failed or didnt seal correctly
Old Feb 16, 2012 | 08:08 PM
IAFF alumni's Avatar
IAFF alumni
Percys get a lot of love.
http://www.summitracing.com/parts/PHP-66031/
Old Feb 16, 2012 | 08:11 PM
STL94LT1's Avatar
STL94LT1
I've had good luck with Percy's Seal4Good header gaskets.
Old Feb 16, 2012 | 08:15 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Percy's High Performance 66031
http://www.summitracing.com/parts/PHP-66031/?rtype=10
Old Feb 16, 2012 | 08:25 PM
HAD2HAV2's Avatar
HAD2HAV2
I have an 88 with the L-98 engine. Previous owner had replaced the stock exhaust heads with "shorties". The paper exhaust gaskets cracked. The Aluminum OEM gaskets were expensive but I bought them any way. A few years later I got tired of using a special tool to remove one spark plug. I bought a set of salvage yard OEM exhausts and bought Fel-Pro exhaust gaskets for $25 for a set vs $50 for one side of the aluminum and they lasted for 12 years until I did some head cylinder work. They were in prefect condition when I removed them, not broken or cracked. That's just my story. Bought them from Summit.
Old Feb 16, 2012 | 08:34 PM
derekguzz's Avatar
derekguzz
How do I know what will fit my header ports? and because of the thicker gaskets, do I need longer header bolts?
Old Feb 16, 2012 | 11:02 PM
IAFF alumni
The links given above are for an LT1 motor, tho you did not state what you have.
The header gaskets are not so thick that you need longer bolts.
Old Feb 16, 2012 | 11:20 PM
derekguzz's Avatar
derekguzz
I stated I have a 94 vette, which has the LT1 motor in it. Do I need to find gaskets to match my headers or heads or both?
Old Feb 17, 2012 | 09:44 AM
IAFF alumni
Yes you did state it was a 94, but there were 2 motors available in 94, the LT1 and the LT5. Now that we know that...
If your LT1 has the stock heads and the headers you are buying are made for that particular motor, the gaskets shown in the above links will fit.
Brand : Percy's High Performance
Manufacturer's Part Number: 66031
Part Type: Exhaust Header and Manifold Gaskets
Product Line: Percy's Seal-4-Good Header Gaskets
Summit Racing Part Number: PHP-66031
UPC: 750140660311
Port Style: D-port
Gasket Material: Aluminum
Quantity: Sold as a pair.
Old Feb 17, 2012 | 09:47 AM
Nathan Plemons's Avatar
Nathan Plemons
I've had good luck with both the copper and the dead soft aluminum gaskets. The key is getting them installed and tightened down properly the first time. I find a little bit of arp's assembly lube on the threads works wonders as well as the proper offset wrenches
When I first installed my headers year ago I got 12 point stainless bolts. These were useless as I could not ever get them tight so most of them are on the side of the road SOMEWHERE in this town.
Old Feb 17, 2012 | 02:21 PM
derekguzz's Avatar
derekguzz
Thanks guys....I will give these a shot !
Old Feb 17, 2012 | 02:27 PM
aminnich's Avatar
aminnich
I put the Percy seal4good gaskets on mine when I swapped in the LT4 and Melrose longtube headers. I am very impressed with them, no problems whatsoever and I used standard header bolts, which have stayed tight and no leaks.
Old Feb 17, 2012 | 02:45 PM
383vett's Avatar
383vett
Whatever gasket you use, spend some time with a straight flile and a straight edge and make sure the flanges are flat. When I had Hookers, it took me quite a while to file them flat. The Mexican made Hookers are pretty bad, even out of the box. I use the Mr Gasket metal sandwiched gasket and haven't had a problem. Have to retorque after a run or two.
Old Feb 17, 2012 | 04:49 PM
Alan777's Avatar
Alan777
There's links to LT-1 gaskets, but how about for the L98 guys? Fel-pro?
To Best header gaskets?
