A/C problems...it's getting hot in Texas.....Automatic controller bad??
Old May 14, 2002 | 04:18 PM
thmupr's Avatar
thmupr
Default A/C problems...it's getting hot in Texas.....Automatic controller bad??
Sorry for the long post... My '92 coupe has some problems with the A/C and sometimes the heater too. I believe that the automatic climate controller might be bad, but I am not sure. When I turn the temp all the way to 60 deg., the A/C does not cycle, or blow cold air. The fan speeds work fine though. I jumpered the low pressure freon switch, but still no A/C. I did check the pressure with guages, look to be OK, considering the compressor will not run. Any ideas??? I did notice last night that when I turn the heater all the way to 90, I am not getting hot air either. :confused: :confused: Does anyone know if the controller can be rebuilt? Thanks in advance..
:cheers: :flag
Old May 14, 2002 | 04:20 PM
2012 coupe's Avatar
2012 coupe
Default Re: A/C problems...it's getting hot in Texas.....Automatic controller bad?? (thmupr)
I had some what the smae problem with my 1992 A/C control head a couple of years ago. Was acting up and not working right. I remeved the control head and cleaned the contact. It has worked great ever sense. Just a thought.
:flag
Old May 15, 2002 | 11:02 PM
thmupr's Avatar
thmupr
Default Re: A/C problems...it's getting hot in Texas.....Automatic controller bad?? (Danah92LT-1)
Thanks for the reply. I'll try starting there. Anyone have repair info if needed?
:cheers:
Old May 16, 2002 | 05:25 AM
pablocruise's Avatar
pablocruise
I don't know if it'll help cuz it was the opposite prob(I don't recall if the A/C blew cold or not-sorry-), but I'll throw it out there since it shows the controller:
http://forums.corvetteforum.com/zerothread?id=202649
www.idavette.net/tech/c4diag.htm
also do a search the archives on your topic. type in climate control and lots of good info comes up.
Old May 16, 2002 | 10:44 AM
Jim D's Avatar
Jim D
Default Re: A/C problems...it's getting hot in Texas.....Automatic controller bad?? (89 Paul in Cal)
The first thing I would do is check the fuse for the compressor, then I would disconnect the battery for 5 min then reconnect and see if it runs good luck Jim
To A/C problems...it's getting hot in Texas.....Automatic controller bad??
