weather stripping
Old Feb 19, 2012 | 02:44 PM
garyajaz's Avatar
garyajaz
Cruising
Default weather stripping
Hi all.
recently bought a 1989 money pit.
been working on it last few weeks.
finally got the cluster worked out and a few other problems solved.
my newest project is the weather stripping. most of ones i was shopping had rotted out
rubber. this car in its former life was garage kept in air conditioning.
its weather stripping is great.
question is how do i keep it that way?
is ther a spray or something i should treat it with?
silicone or some special stuff?
other question is the (abs plastic?) air cleaner. its screw tab is broken. i have the part.
have tried several 2 part epoxies to hold together. even with very light pressure from the hold down screw it just lifts out.
poor bonding. any advic
Old Feb 19, 2012 | 03:41 PM
1986coupe's Avatar
1986coupe
As for the weatherstripping, there are several products on the market that will keep the weatherstripping in good shape. I am not too fussy because I know that opinions change rapidly about what is good and what isn't...kind of like shampoos.
As for your air cleaner, here is a post on that
http://forums.corvetteforum.com/c4-t...-radiator.html
Old Feb 20, 2012 | 11:22 AM
Bowtie30's Avatar
Bowtie30
If you are talking about the tab on the air filter housing I used JB Weld to repair mine and it worked great. I had also tried the 2-part epoxy with no sucess. Good luck.
Old Feb 20, 2012 | 11:39 AM
garyajaz's Avatar
garyajaz
Cruising
thanks bowtie. have jb and use it for everything.
was told the abs plastic it would not bond.
Old Feb 20, 2012 | 11:40 AM
garyajaz's Avatar
garyajaz
Cruising
86 coupe i have NO idea of the stuff to use on weather stripping.
what is one of the several of which you speak?
thanks, gary
To weather stripping
