Halfshaft U joint replacement procedure
Old Feb 20, 2012 | 08:00 PM
97VetteDan's Avatar
97VetteDan
Default Halfshaft U joint replacement procedure
What is the procedure for replacing the rear right halfshaft U joint on a 1990 Corvette?
Old Feb 20, 2012 | 08:31 PM
rithsleeper's Avatar
rithsleeper
There is a detailed write up somewhere on here. Basically when I did mine I removed the bolt for the lower control arm and the spring and then when I removed the straps on both half shafts and then pulled it out by wedgin a screw driver and pulling it out from the differential side. And then the other side will release. Be gental, didn't take too much prying. Then just reverse that once the new ujoints are in. As for pressing them in I used my vice and a big socket and it was pretty simple to press fit it in and out.
Old Feb 22, 2012 | 03:28 PM
TA's Avatar
TA
http://personal.tmlp.com/scorp/vette/images/ujoints/
Old Feb 22, 2012 | 11:11 PM
mtwoolford's Avatar
mtwoolford
very, very nice
Old Feb 23, 2012 | 07:53 AM
1991Z07's Avatar
1991Z07
Wow...did he ever go about that the hard way!
All that needs to be removed is the spring bolt and the bolt holding the camber rod to the knuckle on the bottom...that's what it tells you in the service manual.
Then you won't screw up the alignment...
Old Feb 23, 2012 | 11:46 AM
oldalaskaman's Avatar
oldalaskaman
i vote for this one
Old Feb 23, 2012 | 11:48 AM
RUU's Avatar
RUU
One thing I'll add is to remove the outer (hub/spindle end) u-joint straps and separate that end before the inner as the u-joint could be frozen to the spindle & it's near impossible to get the leverage to get it unstuck while the knuckle is hanging loose. With the half shaft still connected at the diff, you can whack the knuckle with a mallet to pop the u-joint off the spindle.
Old Feb 26, 2012 | 12:25 AM
97VetteDan's Avatar
97VetteDan
Thanks everyone for your help! I now have two new U Joints and New Shocks all the way around!
Old Nov 9, 2013 | 03:15 PM
ped299's Avatar
ped299
7th Gear
Default corvette guy
1989 c4 corvette . what moog universal joint should I use to replace the 4 half shaft u joints
Last edited by ped299; Nov 9, 2013 at 03:21 PM. Reason: rebuilding my my dana 44 rear end
Old Nov 9, 2013 | 03:35 PM
tunedport85inject's Avatar
tunedport85inject
http://www.fme-cat.com/overlays/part...=#.Un6b8_lWw40
Rock auto has anti galvanic coated Ujoint for aluminum halfshaft,they list it as 231c
http://www.rockauto.com/catalog/x,ca...,parttype,2392
Old Nov 9, 2013 | 03:45 PM
WVZR-1's Avatar
WVZR-1
If you're wanting Moog you have two choices 231 which does NOT have the anti-galvanic coating and a 231C which does. Neither of those should have zerks. Buy local and just let the "parts guy" do the work. If you mention you'd like a 1350 series Spicer most could change that number. Is the galvanic coating critical? I'd think NOT if it changes the price or availability dramatically. I would avoid an Internet purchase! I would certainly avoid "RockAuto.
If you use the posters 1st link in #10 which is wrong but enter the 5-1350X the newest Spicer in the "search block" top left it will reference the 331, the 231 is the same joint less the zerk and the C = coated.
If they offer you a 331 that would be with the zerk. Your decision!
Old Mar 25, 2015 | 01:42 PM
jakenks's Avatar
jakenks
I know this is an old thread, but there is nothing at all wrong with Rock Auto. Often times it has parts listed, often OEM, that are no longer available at local sources.
To Halfshaft U joint replacement procedure
