does anyone know if the ZZ4-fast burn engine will bolt into the 1986 corvette and allow the stock fuel injection to bolt on, and retain the stock accessory drives ? the car has been converted from a 4+3 to the richmond 6 speed.
From: And on the fifth day, subpoenas were served to Obama senior staff
Re: engine for 1986 with manual trans (Charles B. Lovelady M.D.)
Hmmm, welcome to the forum Doc!
It will bolt up like any sb chevy. Not sure about the fast burn. If it has fast burn heads you will need the intake manifold from SD to mate to the TPI system. That is if I'm guessing right and that has the aluminum vortec heads. Standard ZZ4 crates are basically an L98 and use later model L98 D port heads but the cam may be better suited to a carb. Others will hop on that can answer better than I.
