Kevko Oil Cooler
Old Feb 21, 2012 | 05:08 PM
LD85's Avatar
LD85
Default Kevko Oil Cooler
Looks Interesting
Part# OC-1
Kevko Oil Cooler
This compact unit can reduce your oil temperature up to 50 degrees. With it's #10 oil inlets and outlets, It can easily be plumbed to your engine cooling system, using mounting points to the firewall, roll bars, or decking. The cooler weighs 4 lbs and the dimensions at 15 1/2 X 4 X 3 3/4.
$235.00
Old Feb 21, 2012 | 06:10 PM
85vet's Avatar
85vet
Cruise-In V Veteran
I use a kevko oil pan - Only pan I have used that does not leak.
They make a very high quality product.
Old Feb 21, 2012 | 06:17 PM
LD85's Avatar
LD85
I use the same pan you use on your recommendation , both Kevko and Champ are top quality pans!
I might dump the factory oil cooler and install this Kevko piece
To Kevko Oil Cooler
