Car won't turn off..
Old May 14, 2002 | 08:46 PM
rmedina's Avatar
rmedina
Default Car won't turn off..
I going to need some help with this one..
Got in my car today started it (which was fine) until I noticed that the antilock light was on. So I figured I would just turn her off and restart. My baby would not turn off. The key was stuck in the run position. So when I got home I disconnected the battery to kill the engine.After playing with it, I was able to turn the column to the off position to take the key out. So my question: Do I need a new ignition switch or ignition lock cylinder? Also do you think this has some thing to do with the antilock light staying on?
thanks,
Raul
Old May 14, 2002 | 10:25 PM
Janaelen's Avatar
Janaelen
Default Re: Car won't turn off.. (rmedina)
Let me guess, your car is an auto right?
Make sure your transmission is fully engaged in park when trying to remove the key. I had to get some adjustment on an '85 I used to own and it worked just great. It could possibly be the ignition switch but I doubt it.
Old May 14, 2002 | 10:57 PM
Corvette0096's Avatar
Corvette0096
Had the same problem a couple months ago. Ignition switch was bad. The part where the keys go in...
To Car won't turn off..
