Does the seat trapeze work?
Old Feb 23, 2012 | 01:30 PM
ggroller's Avatar
ggroller
Default Does the seat trapeze work?
http://www.mamotorworks.com/corvette...1-52-7078.html
Has anyone used this? Does it work?
Old Feb 23, 2012 | 01:42 PM
VetteMed's Avatar
VetteMed
I used it on my seats, since they didn't have any straps present when I bought them (used). It raises the seating position up a few inches, and makes the seat much firmer.
Old Feb 23, 2012 | 02:15 PM
ggroller's Avatar
ggroller
Thanks. Do they go up at the headrest or lower on the back of the seat?
My headrests are lower than the plastic back of the seat and at first I thought I would need to replace the foam but that's not the case. If I push up on the headrest of the seat it fits perfectly. I just need something to keep it there.
Old Feb 23, 2012 | 02:20 PM
VetteMed's Avatar
VetteMed
Stretches across the bottom of the seat frame (base). Nothing to do with the headrest, not sure how to remedy that situation that you describe.
Old Feb 23, 2012 | 02:32 PM
ggroller's Avatar
ggroller
Damn. I was all excited there for a minute. Oh well, back to the drawing board.
Old Feb 23, 2012 | 03:21 PM
VetteMed's Avatar
VetteMed
The foam under the leather does compress and deteriorate over time -- you might be able to find an upholstery shop that could re-stuff that area of the headrest to bring it higher up. I'd probably suggest taking the seat out, and removing the back cover to see what's really going on where you can't currently see.
Old Feb 23, 2012 | 03:44 PM
ggroller's Avatar
ggroller
The head rest part isn't attached to the plastic seat back at all. Is that normal?
Old Feb 23, 2012 | 03:46 PM
VetteMed's Avatar
VetteMed
Not sure, I've never taken one apart. Probably want to post a new thread asking about the headrest problem, you'll get more helpful traffic that way. Also the year of the car is important, so include that in your post.
Old Feb 24, 2012 | 11:02 AM
cadwiz_01Z's Avatar
cadwiz_01Z
Veteran: Marine Corps
From: When Democracy becomes tyranny, the armed citizens will still get to vote!
Sounds like someone took it out and couldn't get it hooked back. There are clips on either side on the plastic seat-back. On the seat-back foam, there are areas of exposed rods (foam support frame) that slip into the into the clips on the plastic seat-back. Here is a good thread with pictures.
Old Feb 24, 2012 | 11:34 AM
ggroller's Avatar
ggroller
Ah ha. You are correct, sir. Thanks for the help. I appreciate it.
Old Feb 24, 2012 | 12:15 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Here are some more pics, in case you need them......(1992 sport seat)
And in case you also want to know about the "trapeze" in the seat bottom, here is what I did to stop the sagging. (Uphostery straps with velcro.)
Old Feb 24, 2012 | 12:29 PM
ggroller's Avatar
ggroller
Thanks. Very useful info. It appears that the previous owner swapped the driver and passenger seat backs because the passenger seat actually shows more wear than the driver's seat.
To Does the seat trapeze work?
