Weatherstripping??
Seen prices all over the place from $80 to 200.
Thoughts opinions..
I just had the complete set installed on my coupe a few months ago...the body shop will hate you but you'll be glad if you do it.
The doors won't "just" shut anymore on mine. The door seals are exactly like it was when I got it new...I've got to slam the door shut to compress the seals. Same with the rear hatch seal, and THAT is FAR better than the OEM one was. The body shop said it was the best seal kit for a C4 Corvette they've ever seen.
Had to feel sorry for the guy who had to do all the scraping & sanding to get back to a bond-able surface...took him 2 days just getting all the old ones out
Just didn't want him to think it was identical to OEM. I have no complaints with my Wilcox stuff, just not the same as the factory weatherstripping. It is a little thicker and not quite as supple. Also, the hatch piece has a reinforcement in the corner to prevent separation. I didn't even use the adhesive to seal mine yet (replacing cracked window soon) and it seems to work fine.
It did not look great out of the box but I had already removed mine so I was stuck using it.
