Replacing 85 Corvette Steering Wheel
Old Feb 3, 2014 | 08:12 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I used a nardi which resembles the Momo adapter. I also had to get the spacer/adapter from Sick Speed to get the wheel to mount to the adapter. I was just about ready to press the adapter on the splines when I realized there were no drilled & tapped holes for a puller if it had to come back off. I drilled & tapped two holes in it and got it all together. It was a pia but I like the look of the new wheel. I checked ebay and right now the nardi adapter is not listed.
Old Mar 13, 2017 | 05:59 PM
Joel C Fischer's Avatar
Joel C Fischer
1st Gear
Default Was it tilt and telescopic?
Originally Posted by USAsOnlyWay
I put a momo on my 86, potentially the easiest thing I have ever done on the car. Only one problem, the new wheel looks so good the rest of the car looks older...
Was it tilt and telescopic? Momo adapter? Did the horn and telescopic work out? Diameter? I'm getting ready to do my 85 and it looks like you're my answer man.
Old Mar 13, 2017 | 09:57 PM
HAD2HAV2's Avatar
HAD2HAV2
If the leather is not torn you can restore it like I did.
After sanding off the old color
another shot
Finished product. Primer from Lowe's and vinyl paint & clear from NAPA.
Old Dec 17, 2021 | 10:58 PM
johnfin's Avatar
johnfin
Default Stitched
Was the 84-85 wheel stitched? Look at this one. Looks molded.
ebay 152829905100
Old Dec 21, 2021 | 11:27 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
ebay 152829905100
Not a corvette steering wheel
Old Dec 24, 2021 | 07:56 AM
johnfin's Avatar
johnfin
Default Wheel
How can you tell? Says its original.
Old Dec 24, 2021 | 09:19 AM
84 4+3's Avatar
84 4+3
ebay 152829905100
mine is definitely stitched and original to the car.
Old Dec 24, 2021 | 08:32 PM
Cruisinfanatic
It's not
Old Dec 26, 2021 | 06:28 PM
Dutch84's Avatar
Dutch84
I have been trying to find the correct hub adapter so I can run a racing steering wheel. Does anyone know the correct hub adapter to run a quick release?
Old Dec 27, 2021 | 07:43 AM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Good question worthy of its own thread.
