Lt-1 = 2 bolt or 4 bolt ???
Old May 15, 2002 | 02:59 PM
vvv90's Avatar
vvv90
Default Lt-1 = 2 bolt or 4 bolt ???
Are they 2 or 4 bolt mains?
If they are 2 bolt, how much HP typically can this take? Pistons, rods, and crank should be the first to get upgraded for increased HP I know, but how much until the main is a concern?
Old May 15, 2002 | 03:01 PM
guywade's Avatar
guywade
Default Re: Lt-1 = 2 bolt or 4 bolt ??? (vvv90)
pretty sure it's a 4 bolt , but thats about all i can tell you :D
Old May 15, 2002 | 03:06 PM
Nathan Plemons's Avatar
Nathan Plemons
That's a slightly complicated question.
The LT1 in the Vette was a 4 bolt, the LT1 in everything else was a 2 bolt. As for HP, well I've seen a 2 bolt engine stand an F-body onto the bumper. The shot of nitrous required to do that put him up to around 600 rwhp. He had forged pistons and rods with a stock crank and stock block. He MIGHT have ARP main studs or bolts, I'm not sure.
With this in mind the 2 bolt is very strong. A 4 bolt is exteremely strong and you shouldn't ever have any trouble with it. However if you do have trouble you can go for the ultimate in strength, 4 bolt splayed. I imagine this would take just about anything you could possibly throw at it. Chances are ANYTHING else will break before you have trouble with a 4 bolt or 4 bolt splayed block.
BTW, here's the F-body on video.
http://www.wku.edu/~nathan.plemons/video/wheelstand.mpg
Old May 15, 2002 | 03:23 PM
vvv90's Avatar
vvv90
Default Re: Lt-1 = 2 bolt or 4 bolt ??? (Nathan Plemons)
Wow!!!! That's a bad butt camaro...hmm, or at least WAS a bad butt camaro, can you say "stress cracks"
Thanks for the info, I just wanted to be sure.
[Modified by vvv90, 7:24 PM 5/15/2002]
Old May 15, 2002 | 03:36 PM
Nathan Plemons
I believe the car was fine except for the fact that he cracked his bellhousing on the way down. He did run it again that day though, but on a much milder shot of NAUWS!
Old May 15, 2002 | 04:33 PM
vvv90's Avatar
vvv90
with that combo of power and traction wheely bars are a pretty reasonable investment wouldn't you say? :yesnod:
To Lt-1 = 2 bolt or 4 bolt ???
