Please help!! Click Click Click when starting.
Old Mar 2, 2012 | 11:05 AM
bpdfs's Avatar
bpdfs
Default Please help!! Click Click Click when starting.
Hi all!
I have a 1993 40th.. (automatic) All stock
A new battery was put in less then a year ago.. The car been running great... I went to start it yesterday and it would just click click click click click.. Battery tests fine and is fully charged.. Everything comes on, (radio, air, etc...) just wont turn.. I am thinking the alternator but wanted other peoples oppinion.. As it is stuck in my garage, Not wanting to have it towed, possibly fix it myself???
any ideas would be GREAT appreciated!
Bryan
Old Mar 2, 2012 | 11:20 AM
bpdfs's Avatar
bpdfs
Bump..
Old Mar 2, 2012 | 11:23 AM
pipe's Avatar
pipe
Sounds like your Starter or Bendix on the Starter is bad. Just get a new Starter but not from GM they want big $ cause it's for a Vette. Try your local auto parts store. GOOD LUCK Pipe
Nathan Plemons's Avatar
Nathan Plemons
The alternator has nothing to do with starting. If the battery is known to be good and fully charged you either have a loose connection, a corroded connection, or a problem in the starter itself.
Check your battery cables to make sure they are clean and tight both at the battery AND at the chassis. Do the same at the starter.
Old Mar 2, 2012 | 11:24 AM
bpdfs's Avatar
bpdfs
where did you get it from? how much? Did you do it yourself?
Old Mar 2, 2012 | 11:26 AM
bpdfs's Avatar
bpdfs
Connections are not corroded and everything looks tight......
summerst's Avatar
summerst
About 10 years ago the starter in my 1991 froze up. Not sure how I diagnosed it other than it just would not turn the engine over. The tow truck driver said that he could get it freed up by banging on it with a hammer. He tried but nothing happened. Turned out it was the starter. For me, the starter worked one day fine and not the next. Go figure. The starter in the 1991 is a bit different than the standard small black variety (I believe is has an aluminum housing). Maybe that could have something to do with freezing up.
Old Mar 2, 2012 | 11:30 AM
Nathan Plemons
Looks tight or is tight? What about the engine to chassis grounds?
Also how do you know the battery is good? Yes it's fairly new and you say it is fully charged, but is it maintaining that charge under a load?
Any auto parts store can load test your battery and they can test your starter for free.
Old Mar 2, 2012 | 11:46 AM
Hooked on Vettes's Avatar
Hooked on Vettes
Inside the starter is a copper disc that bridges two copper lugs to transfer 12 volts to the starter motor. The copper disc and lugs eventually pit and make poor contact.
The noise you're hearing is the solenoid plunger pressing against
the two copper lugs.
If your battery and cables are good take a look at the starter.
You can purchase the parts on-line (such as ebay) or remove the starter and file the copper disc and lugs so they make better contact.
On some solenoid plungers you can flip the copper disc and
use the backside.
Watch the video link below. It the describes the problem and repair.
Only simple hand tools needed for the repair.
http://www.nationsautoelectric.com/densoparts.html
Old Mar 2, 2012 | 12:01 PM
bpdfs's Avatar
bpdfs
The battery is brand new, Not even 50 miles driven on it yet.. Everything is tight, I just checked it all out...
Old Mar 2, 2012 | 12:04 PM
bpdfs's Avatar
bpdfs
use the backside.
Here's a video that describes the problem.
is that hard to do? If i did it myself? Trying to avoid having it towed......
Old Mar 2, 2012 | 12:07 PM
Nathan Plemons
Brand new doesn't mean good, nor does it mean fully charged.
I know it sounds like I'm trying to be an ***, but I assure you I am not. The problem is most likely the starter itself, but you can't assume that just because something is new that it is not your problem.
If you can get under your car, remove the starter, it's 2 bolts. Take it and the battery to a parts store and have them test them both for you. If either one is bad, then you'll know for sure. If they both test good, then you have another problem.
Old Mar 2, 2012 | 12:37 PM
bpdfs's Avatar
bpdfs
no i get it.. i had it charging overnight to be sure... so it should be fully charged and drove it 5 days ago as well..... just 2 bolts? no wires.. where at exactly under car
Old Mar 2, 2012 | 12:55 PM
Nathan Plemons
Your automatic with factory exhaust will look different but the starter should be the same and in the same place.
Old Mar 2, 2012 | 04:40 PM
bpdfs's Avatar
bpdfs
could fuses be a cause????
Old Mar 2, 2012 | 04:45 PM
bpdfs's Avatar
bpdfs
currently car is off.. Battery dead now, tried messing with it.. I dont knwo what wrong......
but car is off and i here click click click click under the passenger side glove box??? what the heck is that?
bpdfs's Avatar
bpdfs
the charger wont charge it either now.... dont get this very frustrating.
To Please help!! Click Click Click when starting.
Old Mar 2, 2012 | 05:19 PM
bpdfs's Avatar
bpdfs
i unplugged the battery. cleaned it still no go.. Now on the display in car says passive keyless entry whats that mean?????
Old Mar 2, 2012 | 06:07 PM
Nathan Plemons
Will your charger charge the battery if it is not connected to the car?
Old Mar 2, 2012 | 08:13 PM
bpdfs's Avatar
bpdfs
dont know.. Didnt take it out, to do it..
I looked at the fuse block right behind it.. The fuses are dusty white like some corrosion.. I think the car is in bad shape, Im going to have it towed..
