1993 wont start
Old Mar 2, 2012 | 08:37 PM
WLRDLR's Avatar
WLRDLR
Default 1993 wont start
I parked my 93 approx 10 years ago & it ran o/k then.I am trying to get it running again. It turns over but wont start. I replaced the fuel pump & cleaned the tank. The fuel pump is not working. If I squirt ether in it it tries to start. Is there anything in the security system that keeps the pump from running? Any ideas? Thnx
Old Mar 2, 2012 | 08:44 PM
THE 383 admiral's Avatar
THE 383 admiral
With it sitting that long. I would check your rails for pressure.. seals might be destroyed
Next. Ohm test your inj.. a spray pattern test the inj's may be gum'd
Old Mar 2, 2012 | 09:35 PM
WLRDLR's Avatar
WLRDLR
Default 93 wont start
Shouldn,t the fuel pump run anyway?
Old Mar 2, 2012 | 09:45 PM
Nathan Plemons's Avatar
Nathan Plemons
Fuel pump runs for about 2 seconds when you first turn the key to the on position to prime the system then shuts off until the engine actually fires.
Old Mar 2, 2012 | 09:53 PM
THE 383 admiral
Without pressure. 43#s Your pump could run all day long
And not start... Also Your regulator diaphragm could have deteriorated
Borrow a efi fuel tester.. they run about 28ish
Are you saying after you replaced your pump it does not prime???
Old Mar 2, 2012 | 10:00 PM
THE 383 admiral
Check your FP relay... also check the wires on the 2 oil pressure switches in the back of the block & notch on the intake check for 12v @ the fuel pump
Old Mar 2, 2012 | 10:06 PM
WLRDLR's Avatar
WLRDLR
The pump doesn,t run at all.
Old Mar 2, 2012 | 11:21 PM
FrankieD's Avatar
FrankieD
10 yrs is quite a long time. Any signs of possible mice/rodent damage to wiring?
To 1993 wont start
