24lb. injectors are available for little extra cost.Would I have to have ecu altered to run the 24lb?
Is it worth the hassle?
Motor is pretty much all stock.
What would you hope to achieve by running larger injectors on a stock engine;
the engine can only use so much fuel ?
and the 22's were installed by the factory for a reason.
And yes;
if you change the injector size you need a retune
And yes;
simply testing the waters.
chose to keep the rebuild 98% stock for the same reason as well
if there were proven advantages I wanted to hear about them.
I will more than likely purchase the 22# injectors. Should run better on all 8 cyl. cant wait to see how it runs after the install.
