Heating Problem..
Old Mar 3, 2012 | 11:48 PM
DA1984VETTE's Avatar
DA1984VETTE
Default Heating Problem..
I have an 84 and it won't come up to operating temp. It used to run between 195-200 degrees now it won't get up past 165 degrees and sometimes less. I know one cause could be the thermostat stuck open, but I have another question. I replaced the engine coolant sensor broke it taking off some of the emission stuff, if this is not installed correctly could this be causing the temps to run low. The last thermostat was installed about two years ago.
Old Mar 4, 2012 | 12:09 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Sensors must be installed using a sealant that won't inhibit grounding. If the wrong kind of sealant were used, it might be possible. Another cause is insufficient coolant. Normally, you'd be able to tell that later by the temperature of air coming thru the heater core.
Of course, even new stats can be bad. You'll find it often recommended to submerse a new stat in water (on your stove) with a meat thermometer to verify correct operation.
Old Mar 4, 2012 | 12:35 AM
DA1984VETTE
The sensor came with sealant on the threads. When the heater or defrost is on there is hot air coming out of both.
Old Mar 4, 2012 | 01:03 AM
vetteoz's Avatar
vetteoz
Assume you are only going by the temp gauge and have not confirmed actual engine temp
when gauge is reading low?
Check what is showing on the temp gauge with the true engine temp
Use a thermo gun or buy a cheap mechanical temp gauge to compare with
To Heating Problem..
