Which water pump?
Old May 15, 2002 | 08:16 PM
November Soul's Avatar
November Soul
Default Which water pump?
I need a new water pump for my '86, the one from my dealer is over $250 :eek: :crazy:
There are several alternatives from NAPA, which one do I need?
NAPA Water Pump - Remfd
Usually ships in 24 hours. WP 58157 $ 37.99
Engine=5.7 L 350 CID V8
NAPA New Water Pumps Water Pump - New
Usually ships in 24 hours. NWP 555016 $ 58.99
Engine=5.7 L 350 CID V8 Engine VIN=8
NAPA New Water Pumps Water Pump - New - Hi-Perf
Usually ships within 3 to 5 days. NWP 555016H $ 134.00
Duro Pro New Water Pumps Water Pump - New
Usually ships in 24 hours. DPW 1301220 $ 58.49
Duro Pro New Water Pumps Water Pump - New - Hi-Perf
Usually ships within 3 to 5 days. DPW 1301220P $ 116.49
:cheers:
Old May 16, 2002 | 01:02 AM
vettl83's Avatar
vettl83
Default Re: Which water pump? (November Soul)
I've had good luck with the Flow Kooler water pumps I don't remember the price but they were cheaper than the Edelbrocks. Phone 805-544-5615 or http://www.flowcooler.com
Old May 16, 2002 | 02:35 AM
devons88vette's Avatar
devons88vette
I would go with a Stewart Waterpump. go to http://www.waterpumps.com
Old May 16, 2002 | 11:44 AM
Corvette0096's Avatar
Corvette0096
Default Re: Which water pump? (devons88vette)
I have a Stewart in mine and it flow 40% better at a idle than stock. $105 at the door
[Modified by corvette0096, 7:45 AM 5/16/2002]
Old May 16, 2002 | 04:39 PM
ToddAT's Avatar
ToddAT
Default Re: Which water pump? (corvette0096)
Me too! Great pump!
Old May 16, 2002 | 04:40 PM
Rick86's Avatar
Rick86
I got mine from Kragen (rebuilt model) around $50.00 it was a rebuilt GM water pump with the same cast in part number as my original. Seems okay.
Old May 16, 2002 | 08:51 PM
UDLUV12's Avatar
UDLUV12
Default Re: Which water pump? (Rick86)
Bob,
I have an Eldebrock Water Pump in my '86.
P/N: ELD-8815 from Summit's catalog.
At the time I purchased mine, it's cost was $159.95.
Here is what I liked about these water pumps 4 years ago when I made the purchase:
Edelbrock "guaranteed a leak proof water pump, due to the extreme tolerances
under which they were built."
Edelbrock also claimed: "because of the extremely close tolerances...equal cooling would be experienced on both sides of the engine...thus producing more horsepower."
I believe them. My engine has run cooler ever since I installed this pump 4 years ago.
You know the old saying: "you get what you pay for"...well if you ask me, I sure as hell don't want to short change, an engine that I want to produce the most power I can expect from the modifications I've made.
Good Luck with your choice.
Old May 16, 2002 | 10:57 PM
jfb's Avatar
jfb
I recently put a Stewart in my 87 ($104 to my door) and at idle if I see the temp starting to climb, I switch the fan on and down it comes. I recommend going to their site and reading what they have to say about water pumps and cooling your engine. From the way my original GM pump acted, it was clear to me that it didn't pump enough volume at idle to keep the engine cool. The Stewart does.
Old May 16, 2002 | 11:29 PM
Kizmo's Avatar
Kizmo
Default Re: Which water pump? (jfb)
What ever you do don't buy a rebuilt pump. :nonod: :nonod: :nonod:
Spend the extra bread and buy yourself peace o mind. :yesnod: :yesnod:
:seeya
Old May 17, 2002 | 03:43 PM
JAKE's Avatar
JAKE
I tried to find one for my 86 Vette, which is reverse rotation, on Stewarts' website but didn't see one listed.
Does anyone know the correct part number for a Stage 3 or Stage 4 Stewart pump for the 86?
Thanks,
Jake
Old May 17, 2002 | 04:02 PM
cdnguyred88's Avatar
cdnguyred88
Default Re: Which water pump? (JAKE)
I've got a Flow Kooler pump and car runs about 15 degrees cooler at all times. Oil temp is also 10 -15 degrees cooler.
Never have to worry with a/c on and idling in stopand go traffic anymore. :D
Old May 17, 2002 | 10:06 PM
Denney's Avatar
Denney
I just ordered a water pump for my 94 (LT1) and decided on the new GM/Delco water pump. I checked the Stewart site and found that they don't offer one for the LT1 yet, and I can't wait (summer is here!!!). I need to replace the intake manifold gasket, and thought, since I'm here... so it's new water pump, Opti-Spark, plug wires, plugs, belt, hoses, radiator. I have the timing chain set too, but will wait for that.
To Which water pump?
