86 stalls and won't restart till cold
Old 03-07-2012, 12:47 AM
mater916
mater916's Avatar
Default 86 stalls and won't restart till cold
just put new fuel filters and checked fuel pump for pressure and changed relay,runs fine after about 2 miles stalls and won't start? any ideas?
Old 03-07-2012, 05:54 AM
S.D.M.F
S.D.M.F's Avatar
Could be a faulty Ignition Control Module. I had a similar problem with my '89. I replaced the fuel filter, the battery and had the fuel system cleaned out. None of that worked until I replaced the I.C.M.
Old 03-07-2012, 08:32 AM
leesvet
leesvet's Avatar
does that mean that you pulled the pump and changed the tank screen/filter?
Old 03-07-2012, 12:58 PM
mater916
mater916's Avatar
yes changed the tank filter
Old 03-07-2012, 01:25 PM
ch@0s
ch@0s's Avatar
Did you ck the fuel pressure when its acting up? Sometimes fuel pumps work fine until they get hot.
Old 03-07-2012, 09:09 PM
mater916
mater916's Avatar
changing the pump tonight,we changed the i.c.m still doing the same,hoping it has to be the pump?
Old 03-07-2012, 10:13 PM
ch@0s
ch@0s's Avatar
I hope so too but just changing the pump is throwing parts at it not diagnosis.GL
Old 03-09-2012, 01:35 PM
myfunz
myfunz's Avatar
Old 03-09-2012, 05:39 PM
nutz4c4
nutz4c4's Avatar
Old 03-11-2012, 12:25 PM
Camelotian
Camelotian's Avatar
Did you check the fuel pressure regulator diaphragm?
To 86 stalls and won't restart till cold
Quick Reply: 86 stalls and won't restart till cold
