You have pseudo carb'd system on that car as it is.....I mean, it's not gravity fed fuel stream, but you can see the injectors squirting into the throttle body just like a carb...
If you want, find a set of '87 aluminum heads, port the throttle body, intake and heads and then report back....see what kind of beast you've awoken.
Reliability - We'll try and see.
Details on the '87 mod please, what sort of HP gains is that?
Unless the existing injection system has proven itself unreiable to you on this car, why not leave it? If you can change the intake manifold (which you'd have to to go carb'd) then why not just get a Rengade intake? MUCH less work that way.
Aside from that, changing the fuel pump would be kind of pointless as well since the stock system is low pressure already. Just use a good FPR to drop it down low enough for a carb.
Personally, I don't see the point of doing the enourmous amount of work to rip all the wiring out of the car and then re-wire it to get it running when there is nothing wrong with the existing system in the first place.
