88 Runner Torque
Old Mar 10, 2012 | 02:02 PM
87FIREREDRAGTOP's Avatar
87FIREREDRAGTOP
Default 88 Runner Torque
Anybody know the torque specs for the intake runners? I can't find it in my FSM. Also, should I use locktight on the runner bolts?
Old Mar 10, 2012 | 02:07 PM
jesredvette's Avatar
jesredvette
I can't remember the source, but I read somewhere that it is 20 lbs.
I would not use locktight on these bolts.
Old Mar 10, 2012 | 09:42 PM
l98tpi's Avatar
l98tpi
Max G’s
25 lb/ft torque. No thread locker. If anything, use anti seize. In your FSM the info is under intake manifold install, at least it should be.
Old Mar 11, 2012 | 11:10 AM
87FIREREDRAGTOP
It's not there. Although my FSM is a prelim. Thanks
Old Mar 11, 2012 | 03:41 PM
WW7's Avatar
WW7
25 ft lbs is correct , below is from a automotive site. And yes use antiseize on the bolts...WW
.Install the runners, gaskets and the runner-to-manifold bolts and tighten to 25 ft. lbs. (34 Nm).
Old Mar 12, 2012 | 10:14 PM
87FIREREDRAGTOP
Thanks Guys.
To 88 Runner Torque
