Intermittent hard shift 1st to 2nd
Is there an adjustment that would smooth out the hard shift?
,may be your governor need to be ceck,governor is a centrifugal valve, located in the tail of transmission driver side inside an housing with a cap(no need to drop transmission from your car).This valve is inside a little shaft connected to the outputshaft by a plastic gear.Sometimes it becomes stucked and doesn't release pressure to upshift.
The weights act on this plunger, which opens and closes a passage in the valve body to control full throttle upshifts.
Thank you for the reply and excellent photos.
There are 171k miles on the tranny. Could this part be worn to where it is needing replacement? What is the best way to test and clean/repair it?
fluid level must be ceck with a warm fluid ,take your car and let it warm,when your engine is warm ceck trans fluid temperature if it is warm ,but not hot,go with trans selector from 1 to N,2 toN,D to N,OD to N,R to N,then put it in P,and ceck level on dipstick,add until you are on the good mark.
I have to go through an intersection with a stop light at the bottom of the on ramp to the interstate. To be able to blend into traffic you need to get up to 65 quickly. Bad design for slow cars as there have been a few accidents there.
It only does it on a WOT takeoff and when it does it is time to hold on.
What I was thinking before I got to the bottom of the thread and saw this.
