Air Conditioner no high blower
Old Mar 11, 2012 | 06:19 PM
LD85's Avatar
LD85
Default Air Conditioner no high blower
My AC works on all notch settings except the high, I replaced the blower relay and that did not help.
Use the search engine but have found nothing related to my problem so far
I'm gonna break out the manual but figured I would check with the "orb of knowledge" forum first
Old Mar 11, 2012 | 06:28 PM
JackDidley's Avatar
JackDidley
Should be a resistor set in the top of the evap box. The coil for high speed may be burnt in two. I have C68, it doesnt have that but your 85 probably does.
Old Mar 11, 2012 | 07:10 PM
LD85's Avatar
LD85
Thanks JD, I will check this out!
Old Mar 12, 2012 | 08:56 AM
vetteoz's Avatar
vetteoz
Have you confirmed power available on the red wire at the relay (direct from batt?)
Not shown in diagram but I suspect a inline fusible link installed close to the starter on your car
Have you confirmed new relay is actually being operated?
Blower switch on dash may be faulty in hi position ( only )
Hi speed power goes direct from batt through the relay to blower motor
Old Mar 12, 2012 | 10:12 AM
T. Wayne Nelson's Avatar
T. Wayne Nelson
I replaced the relay in my 85 and it did not fix the problem, I then ran a hot wire to the relay slot that is the high blower position and the blower worked. I then pulled the relay and noticed that I had bent the prong when I installed the new relay. Straighted the prong and blower motor worked. If all works when you wire it direct and the relay is properly installed, and the motor still does not work in high postition, then it is likely the switch.
Old Mar 12, 2012 | 10:33 AM
LD85's Avatar
LD85
Thanks T-Dub!
The schematic makes it look pretty simple, so I am ready to Succeed!
To Air Conditioner no high blower
