iac 1984
Old Mar 12, 2012 | 03:36 PM
barry.walker's Avatar
barry.walker
4th Gear
Default iac 1984
I took the two iac,s out of my 1984 Corvette to clean them, they didn't look bad but my question is can the pintles be moved by pushing on them? I couldn't move them back like the book says to make sure they won't bottom out on the seats.I haven't ohm ed them yet but if they ohm good but still may not move in engine because stuck,so they could still be bad.with the engine running and the tester hooked up the I AC counts do change a bit, but that just says the computer is sending the info only, it doesn't mean the I AC is actually moving.correct?
Also on the Plentum gasket, does it leak allot ,I need to check this to.
Anybody having any experience on these problems please help
Barry
Old Mar 12, 2012 | 03:50 PM
oldalaskaman's Avatar
oldalaskaman
dont push or pull, gently re install
Old Mar 12, 2012 | 05:42 PM
Rohn's Avatar
Rohn
They can be cycled and visually witness movement only installed in TB. I forget which ALDL pins you jumber. Maybe a search?
Old Mar 13, 2012 | 02:31 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Leaks in your plenum gasket is an absolute no no! In fact, leaks in any gasket is a no no. This plenum gasket is a challenge to get sealed properly, since it's so long and skinny, and a lot of L83 engine builders have problems with vacuum leaks in this area.
Old Mar 13, 2012 | 10:28 AM
Rohn's Avatar
Rohn
I have never changed one but would not the use of "Right Stuff" be a better choice than the gasket?
To iac 1984
