brake line replacement or not
Old Mar 12, 2012 | 10:14 PM
The Plastic Lizard's Avatar
The Plastic Lizard
Default brake line replacement or not
Was wondering what a stainless brake line actually gains a street only car?
None of the rubber ones are leaking, but i am thinking of upgrading lines when i work on the pads next
Do the stainless steel ones really gain anything for daily use ?
Old Mar 12, 2012 | 10:20 PM
oldalaskaman's Avatar
oldalaskaman
they look purty
Old Mar 12, 2012 | 10:33 PM
jd2's Avatar
jd2
If you have the original 84 rubber lines I would think you would get a great amount of peace of mind. At least put new rubber ones on. JD
Old Mar 13, 2012 | 10:02 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Rubber lines deteriorate, please replace your brake lines.
As long as they don't get rubbed or used for racing the DOT braided lines will be great and last a long time. Or put ne rubber hoses on.
Reminds me, my braided lines have been on the race car too long - time to change them.
Old Mar 13, 2012 | 10:06 AM
Nathan Plemons's Avatar
Nathan Plemons
I run braided stainless on my car. They do give me a slightly stiffer brake pedal. The only explanation is that more braking force is going to the calipers where it belongs as opposed to expanding the rubber lines where it doesn't.
Gains? Not so much. I could apply enough braking force to lock up the tires before, I can after. This means you're going to have the same stopping distance.
I used them because I like a firmer pedal, they look better, and should be more resistant to abrasions.
Old Mar 13, 2012 | 10:28 AM
c4cruiser's Avatar
c4cruiser
The brake lines with the stainless woven cover do have a slightly stiffer hose material inside compared to stock lines and that does increase the stiffer feel of the pedal.
The woven stainless wrap is designed to protect the inner tubing from heat and anything that gets tossed into the wheelwell, along with the metal cover being able to reduce the expansion of the hose as fluid pressure increases during braking.
Are they suitable for street driving? IMHO, they are, but like any flexible brake line, they are subject to wear and should be replaced at some regular interval.
Stock style rubber lines are also subject to wear but the outer rubber covering will weaken quicker and as line pressure increases from braking, the internal hose can expand and the rubber will not work as well to maintain fluid pressure. That's why rubber lines feel "softer" as they age.
From pricing stock hose and the stainless lines, the prices seem to be fairly close. I'm using Earl's stainless lines on my 87 autocross/track day car and as they are 5 years old, it's time to replace them even though they look fine.
For street use (or even autocross) stock lines should work fine. Just make sure you get good quality hoses.
Old Mar 13, 2012 | 10:50 AM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
just like I would't drive around on 28 year old tires.
Old Mar 13, 2012 | 10:52 AM
Nathan Plemons
Where is your sense of adventure?
Old Mar 14, 2012 | 11:29 AM
92ragtop's Avatar
92ragtop
I use it up on the weekend when I play with angry wolverines and poke sticks in snake holes.
But seriously, 0-60 is fun, but 60-0 is more important.
To brake line replacement or not
