Sticky shifter?
Old May 16, 2002 | 01:37 PM
Captain_Kaboom's Avatar
Captain_Kaboom
Default Sticky shifter?
Hey all,
My '93 6-speed sticks in a gear everyone once and a while and doesn't want to shift, or getting into a gear is sometimes a bit tough. Had the clutch redone a month or two ago. Any suggestions?
Thanks!
Old May 16, 2002 | 07:46 PM
rocketfinger's Avatar
rocketfinger
Default Re: Sticky shifter? (Captain_Kaboom)
Mine had a similar problem. Drained out what was definitely not the 5w30 gear oil recommended by ZF. Put in the right stuff and it's just keeps getting smoother every time I drive it. De-sludging I suspect. The thinner oil gives a bit more gear noise but is better for taking away heat.
One other thought is a sticking clutch slave cylinder, but they should have noticed that when they did the clutch. This might shine some light into some of the dark corners of the ZF6;
http://www.zfdoc.com/techinfo.htm
[Modified by rocketfinger, 11:51 PM 5/16/2002]
