How do I get to the top 2 bolts out on the front (nearest the engine)? I removed the clamp and I assume I have to remove the heat shield. I can't get at those 2 10mm. bolts on the front of the heat shield either. Then I can't get at the 2 top 9/16ths bolts on the catalytic converter. I'm removing the cat because after 236,000 kms. It's plugged! Thanks1 J.
if you have the rear loose, use a long bar and a hammer , break the rock up in small pieces, start your engine , rev it to blow the pieces out, check to see if they all came out, re-bolt it back up, saves all kind of time
You don't have to pull off the heat shield. with mtnmanut. It may take a couple of extensions. I don't believe that I had to use a swivel, just a couple of 12" extensions and patience. Once you get the nut off, it will require more patience to remove the bolt from the grip of the heat shield.
I cut the connector that connects the air tube to the cat....you have to tackle that part yet. When I put everything back together with the new cat, I used 1/2" compression fittings to connect the cat to the air tube. I cut the tube about 18" back from the cat and added another compression fitting to make the line up of the tube and the cat easier.
Thanks Guys! Great Man Of The North I like your idea!! Thanks for the pic John! So there is no way to disconnect the connection from the cat to the airtube?
The air tube is attached to the cat with a crimped ring The ring is concave so that it grabs the tube and the tube on the cat. Some on the Forum have used rubber hose to attach the two. I just was not comfortable attached rubber to the cat which gets so hot.
Just so you know, the tube is 1/2" diameter and the compression couplings fit very well. The nice thing about the 85 is that the cat bolts in and out. I take mine out when I go to the track and bolt in a straight through pipe and the air tube bolts right up with the couplings. If you want to see a big difference in power....drop the cat.
I also ended up building my own gaskets. There were no gaskets when GM put this together. Some previous owner had used silicone, but a good exhaust gasket material works well.
