No Start
Old Mar 16, 2012 | 10:22 PM
qws's Avatar
qws
Default No Start
84 that was converted to the HSR a couple of years ago for those that don't know my build
Turns over and wants to fire
Seems to be flooding out, I can press the throttle down and get some air in there and it wants to fire.
It has started twice for a couple of seconds
Fuel pressure is good at 43.5
Spark has been tested and confirmed, pulled the plugs and they are wet
Sat all winter and put in a new tranny, checked to see if I've knocked off any wires and it doesn't appear that I have
Could I have flooded it to a point where either I've ruined my plugs or needs to sit for a couple of hours and dry out?
Kinda just sitting and waiting for it to dry out know...so I figured I'd post to see if any of you might have some other ideas.
thanks
Old Mar 16, 2012 | 11:36 PM
jfb's Avatar
jfb
Wet plugs won't fire. You need to find out why you have excess rich condition when starting. I think on 84's you can hold the throttle down while cranking and this shuts off the injector and allows drying out cylinders. I may be wrong about this.
Old Mar 16, 2012 | 11:37 PM
cv67's Avatar
cv67
St. Jude Donor '05
Instead of waiting for the spark plugs to dry off of raw gasoline,
get a propane torch like a Benzomatic & dry them off with the flame for 10 to 15 seconds each.
You can clean them further with Carb cleaner.
Don't use brake cleaner.
brake cleaner with carbon tetrachloride will permantly foul the spark plug projected porcelain tips. Leaves an invisible highly conductive film that a high Kv spark love to travel on instead of jumping across the J- spark plug gap as it normally would.
Also take a squirt oil can & shoot 3 or 7 shots of your favorite engine oil into each cylinder.
10w30 is great.
Old Mar 16, 2012 | 11:39 PM
cv67's Avatar
cv67
St. Jude Donor '05
Holding the gas down WOT while cranking works on all GM EFI equipped cars since at least 1983 & Fords too.
Old Mar 16, 2012 | 11:45 PM
qws's Avatar
qws
10w30 is great.
OOPS!... I used brake cleaner on them the other day.
I did finally get it running, ran very rough but finally smoothed out.
I have another set of new plugs for it ...maybe I'll throw them in.
thanks guys for your replies
Old Mar 17, 2012 | 12:01 AM
cv67's Avatar
cv67
St. Jude Donor '05
Throw the new plugs in.
Brake cleaned spark plugs are now junk.
Will pop & miss bad under WOT driving & high speed runs.
To No Start
