94 power window motor replacement questions
Old Mar 17, 2012 | 04:51 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Default 94 power window motor replacement questions
follow up on my last post about my passenger side not working. did some testing today and it seems like the motor is shot. followed the chart in the FSM. so I figured I need to replace the motor. but in the FSM it says to lower the window 3/4 way down. how do you do that when it doesn't work?
and how bad of a job is it to replace it
Old Mar 17, 2012 | 10:46 PM
Nowhere Man
I must have a bad ground. because it all works like it should and I did not do anything to it.
Old Mar 18, 2012 | 03:42 AM
hitmanpty's Avatar
hitmanpty
I did change my 2 window motor regulators. First door took me about 3 hours to complet. But the second door. Just took me 45 minuts. Because after doiing the first one. Give me the know how to do the second one.
Is not that dificult at all. If i candoit anyone can
Old Mar 18, 2012 | 03:44 AM
hitmanpty's Avatar
hitmanpty
Just check all your connections you will find the problem
Old Mar 18, 2012 | 09:32 AM
jtc44's Avatar
jtc44
Default Power window
IMHO the moter is bad. Some times just moving it or tapping on it will get it to work for a bit but only time will tell. Want a neet trick? Use a old head lit and put to the 2 wires going to the moter if the lights up real bright the wireing going to the moter should be good :
To 94 power window motor replacement questions
