RPO Code Mysteries??
Old May 16, 2002 | 09:10 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default RPO Code Mysteries??
I was just going through my list of RPO codes on my '92 Auto, and came up with a few questions. First, I have the RPO code G44, which is for 3.07 Gears.. However, there is an RPO code, G92 for "Performance Axel Ratio", which I dont have.. I thought that the 3.07 gears WERE the performance axel ratio on the autos..
Also, I have a list of codes, that I could not find anywhere on the net (looked at several sites) and was wondering if someone could fill me on on what they mean:
BGR, B3E, D8L, E5Z, E9Z, IP3, VG8, V73, 1AY, 15A, 19I, 81U
Anyone know what any of these mean? Any info would be greatly appreciated! :)
Old May 16, 2002 | 10:16 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Default Re: RPO Code Mysteries?? (MarkLT1)
Pity Post :lol:
The 3.07 is the performance axle. I'm pretty sure 2.59 were standard with an auto.
BGR BOWLING GREEN PLANT PROCESSING
19I INTERIOR TRIM, BLACK (I) (91)
DL8 MIRROR, O/S LH & RH REM CONT, ELEC, DEFOG (not D8L?)
E5Z SPEEDOMETER ADAPTER (DELETE)
E9Z SPEEDOMETER KEY (DELETE)
IF3 TRIM, INTERIOR DESIGN (not IP3?)
V73 ANTENNA, FIXED (No, mine is not a fixed antenna either :confused: )
1AY ORDER MODIFICATION STOCK
Most of these are on my 92. :D
Old May 16, 2002 | 10:19 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: RPO Code Mysteries?? (Blue 92)
Pity Post :lol:
:lol: Thanks Blue 92..
As for the D8L, DL8, I have BOTH listed.. (And knew what DL8 was).. and the IP3, sure looks like a P to me, but it might just be old paper???
scorp508's Avatar
scorp508
1AY Custom Built Per Dealer Stock Order
BGR Bowling Green
E5Z Speedometer Adapter (Delete)
E9Z Speedometer Key (Delete)
15A Your Trim Combination I think
19I Your Interior Carpet Color
81U Your Paint Color Code
Old May 16, 2002 | 10:23 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: RPO Code Mysteries?? (scorp508)
What do these mean???
Old May 16, 2002 | 11:13 PM
Blue 92's Avatar
Blue 92
D8L SENSOR, VEH SPD
To RPO Code Mysteries??
