Autox align. specs?
Old Mar 18, 2012 | 07:56 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Default Autox align. specs?
Well after all the work I have done on the vette I will need a new alignment. I'm setting the #'s up for autoxing so looking for what most of you are running.
Old Mar 18, 2012 | 08:39 PM
Nathan Plemons's Avatar
Nathan Plemons
http://www.vbandp.com/View-document-...ent-Specs.html
Old Mar 18, 2012 | 09:15 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Goto Autocrossing & Roadracing.
Old Mar 19, 2012 | 07:12 PM
93Rubie's Avatar
93Rubie
On saturday I spent 2.5 hours getting my Corvette aligned to almost perfection. I did it myself on a Hunter Machine/Rack.
I went with VBP's advanced street setup with a twist. I dialed in -.5 in the front instead of the -.25. All the other specs. same as what they have. My caster is on the lower end at 5.3 Left side, 5.6 right side.
I only drove it at 8/10's on some curves on the way home, but I can say this. Turn in is much sharper, the car feels more neutral, the rear ends wants to follow the front, front sticks better so does the rear. I am anxious to try it at 10/10's in some auto-x.
FYI, I run the car on the street a lot so a strict auto-x alignment is out of the question, I do want SOME tire wear.
FYI, on the left side of my car I only have maybe on the front most part of the upper control arm about 3/32" of shims and 1/32" on the back. So about -.7 or 8 is the most I am going to get from my left side. The right side has 3/16" worth of shims on both positions.
Find a good alignment shop that will take the time to DO a GOOD 4 WHEEL ALIGNMENT. Too many toe and go shops out there.
To Autox align. specs?
