Temp
Old Mar 19, 2012 | 07:56 AM
R ROGERS's Avatar
R ROGERS
4th Gear
Default Temp
Recently purchased a 96 and would like to know the correct temp for the coolant and oil after complete warm-up?
Old Mar 19, 2012 | 09:34 AM
markKlein's Avatar
markKlein
Normal temp for warmed up coolant is between 200 and 230. Fan does not even come on until 228 (If I remember right).
Old Mar 19, 2012 | 09:49 AM
Nathan Plemons's Avatar
Nathan Plemons
If the car has never been monkeyed with the coolant temps will be higher than you would expect. Oil temps generally are a little less than coolant temp for regular cruising, short trips. If you beat on it a hot your oil temps will easily get higher than coolant temps.
Old Mar 19, 2012 | 04:10 PM
R ROGERS's Avatar
R ROGERS
4th Gear
Great to know. Thanks!!!
Old Mar 19, 2012 | 07:16 PM
bac22's Avatar
bac22
I seem to recall my oil temps run around 220.
Old Mar 20, 2012 | 07:28 AM
R ROGERS's Avatar
R ROGERS
4th Gear
With this helpfull info , it seems that I are O. K. Thanks
To Temp
