Coincidence or Fix??
Old Mar 20, 2012 | 10:06 PM
Speedjester's Avatar
Speedjester
Default Coincidence or Fix??
Well the other day I noticed while I was working on the a/c that the outdoor temp sensor was stuck on 40*f ... Checked connections all were fine.. Decided to disconnect battery and see if it resets...and it did... But something else I noticed.. The car no longer stalls out on the first light up like it use to... And the idle seems a bit higher at 675 in park...
So my question is could disconnecting the battery have fixed these gremlins.. I have always cleared previous codes using my Mac taskmaster.. This is the first time I actually disconnected the battery..
Thoughts opinions?
What does disconnecting the battery reset?? (other than clearing codes)
Old Mar 20, 2012 | 10:21 PM
93Rubie's Avatar
93Rubie
Thoughts opinions?
Disconnecting the battery will reset the fuel trims and other "learned" values the ECM uses. They reset back to a default, if you have some sort of issue, the ECM may compensate over time to help correct this issue, however that compensation may have been causing your idle issue. I would drive it and see what happens with a some miles on it.
