hi i need help
Old Mar 21, 2012 | 04:46 PM
q8roma's Avatar
q8roma
Default hi i need help
i have corvette c4 lt1 manual stock and i want to buy
1- http://www.ebay.com/itm/Eagle-Sbc-St...ht_2332wt_1196
2- http://www.ebay.com/itm/Trick-Flow-G...#ht_1565wt_689
is this god or not god
Old Mar 21, 2012 | 05:25 PM
ddahlgren's Avatar
ddahlgren
it may be 'good' but certainly can not buy 'god' on ebay..sigh... at least caps lock was not stuck on...
Old Mar 22, 2012 | 02:28 AM
Shock96's Avatar
Shock96
You will probably get a lot of opinions on these. I think the Eagle setup seems good. I would probably look at other combos for the heads.
You should do a quick search as there is a ton of info.
Old Mar 22, 2012 | 01:51 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
What is your goal?
You have a 383 rotating assembly and a top end assembly as your choices.
If you go 383, it shows .040 over pistons. Lots of machine work, and you'll need to work on the top end as well to get lots of ponies.
Now the two kits together and machine work could be a good runner
Old Mar 22, 2012 | 03:14 PM
q8roma's Avatar
q8roma
in kuwait zo6 is the king street race
i went race zo6 on my c4
i need engine to beat the zo6 and engine daily use. please
Old Mar 22, 2012 | 05:30 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Ahhh, got it.
You want something over 400rwhp.
I'm guessing LSx engines aren't a dime a dozen over there.
Read these two LTx build up threads:
LT4 383 Rebuild
PRLX LT4 Build up
PM a couple of the builders in those threads, ask questions and listen.
Is there a machine shop around that can do the over bore, clearancing for the rods, etc?
To hi i need help
