Questions on the 'hot cam'...
Old May 17, 2002 | 04:31 AM
R Cook 92's Avatar
R Cook 92
Default Questions on the 'hot cam'...
I am currently in the slow process of rebuilding my lt1. it is a 92 block, and I was planning on the hot cam kit. I've done quite a bit of research, but I've heard I would NEED bigger injectors for the bigger cam.... is this true?? Also, will the 1.6 rockers fit under my stock 92 valve covers? Any other problems I should expect??? I know plenty of posts have been made, and I've been through enough of them to keep me reading for hours... Thanks for any help/suggestions...
Old May 17, 2002 | 08:41 AM
silver & red CE's Avatar
silver & red CE
Default Re: Questions on the 'hot cam'... (R Cook 92)
...I've heard I would NEED bigger injectors for the bigger cam.... is this true??
Lot's of folks are running the LT4 HOT cam with stock LT1 injectors, you should be fine. I'd wait a see, they're easy to replace.
Eric
