mechanical pump for tbi
Old Mar 21, 2012 | 11:51 PM
Louis Farmer's Avatar
Louis Farmer
Cruising
Default mechanical pump for tbi
posted in c3 one guy said i might try here since yall run more tbi than we do
Hello I have searched all over the internet and came to the conclusion that nobody has done this, the reason i want to is i dont too much care for electrical stuff. I put in a electric fan and it failed so went back to clutch fan. Im not too good with wiring and i didnt want to cut and flare my fuel lines.
Ok so what i got is a complete tbi from a 95 truck came with the entire wiring harness except tail lights, got blinker bulbs, fuse box, sensors, dizzy, computer, air cleaner, intake, and tb with injectors and some funny looking canister.
its going in my 79 350 currently 750 edelbrock with manual pump. Looking at manual fuel pumps and found 2 same price as inline electric one rated at 10 lbs the other for 15
http://www.ebay.com/itm/330697196020...84.m1436.l2649
http://www.ebay.com/itm/130665235209...84.m1436.l2649
what is the diffrence in pumps as far as will they work the same will they provide the right ammount of flow and whatever else tbi needs read that manual pumps surge fuel and tbi dosent like that too much. like i said im not big on this stuff im more of a welder and painter
and driver
the motor is out of my dads 87 1 ton dulley was gonna take that tbi when we did the swap but i was in too much of a hurry, now im kinda regreting it lol
i have and can do everything else modify my intake to fit the tb run wires that are pre fabbed lol and whatever else that comes along
thanks in advance for the help guys got to the point where i needed to talk to more than 1 person bout this.
Old Mar 22, 2012 | 02:19 AM
vetteoz's Avatar
vetteoz
Think you are asking for trouble.
Any variation in pressure ( surge) or flow is going to throw the tune out the window as the poor computer "tries " to keep fueling correct
With a mech pump ,no prime function so you are going to have to crank the engine
until the fuel pressure comes up ( no fuel at injectors ready like a carb) .
Good EFI engine will fire as soon as the key turned; with little or no crank
There is a reason elec pumps are used , they maintain constant fuel pressure and flow rate ; usually through a bypass regulator.
A mech pump just fills a bucket ( the carb bowl ) so it doesn't matter if flow or pressure varies because the pressure is constant at the bottom of fuel bowl
Old Mar 22, 2012 | 05:38 AM
ddahlgren's Avatar
ddahlgren
Not positive if this would work but why not check to see if parts from an 82 might fix up the fuel delivery problem did that have a CFI so a TB system with appropriate pump and regulator and hopefully a bolt in.
Dave
Old Mar 22, 2012 | 09:47 AM
oldalaskaman's Avatar
oldalaskaman
http://www.google.com/url?sa=t&rct=j...VrFN1k5NcN8viH
posted this in the C3 , but it may help someone here also
To mechanical pump for tbi
