Connector C100 help
Old Mar 24, 2012 | 03:11 PM
Mikky89's Avatar
Mikky89
Default Connector C100 help
I have an 89 and am trying to unplug the engine harness from connector C100 near the battery. The connector is very tight and I cannot get anything to move, plus it is hard to work in that area with the booster next to it and the clutch master above it. What am I missing? The only thing I find in the FSM is a picture.
Old Mar 24, 2012 | 10:11 PM
Cliff Harris's Avatar
Cliff Harris
There is a screw in the center of the connector that holds the mating halves together. I don't remember the size, probably 7mm or 8mm.
On my car the connector was filled with sticky black dielectric grease. Don't remove that. It keeps the connector pins from oxidizing. It gets wiped away from the connection as the connector is mated, so it will not interfere with a good connection. I'm pretty sure GM went to a different kind of grease in later years, but I don't know when.
Old Mar 24, 2012 | 11:12 PM
Mikky89's Avatar
Mikky89
Ah yes and there it is, right in the middle. Thanks
Old Mar 25, 2012 | 01:30 PM
SunCr's Avatar
SunCr
In case you're troubleshooting - Pin Schematic in the '89 Helms Shop Manual is for the '88. You need to use the Electrical supplement.
To Connector C100 help
