'88 Making Noise When Off?
Old Mar 25, 2012 | 10:44 AM
armybyrd's Avatar
armybyrd
Default '88 Making Noise When Off?
Today I just started my '88 for the first time since December. She sounds great and idled just fine. But after I shut the engine off I noticed a ticking noise every few seconds that sounds like its coming from under the plenum though I dont see what would be making noise from there-especially with the engine off. My egr is blocked off if that matters. Also my horns are unplugged. Could it be part of the vats system behind the dash making the noise? Any ideas?
Old Mar 25, 2012 | 11:05 AM
ddahlgren's Avatar
ddahlgren
Could it be the exhaust manifolds cooling off? Hot metal will occasionaly make a noise like you describe when cooling off or heating up from the expansion / contraction of the metal. Maybe check the exhaust bolts?
Dave
Old Mar 25, 2012 | 11:25 AM
armybyrd's Avatar
armybyrd
I actually just replaced the header bolts with locking stage 8s. I just have one bolt left on the passenger side(closest to the firewall) which is why I only let the car idle for a few seconds.
Old Mar 25, 2012 | 12:10 PM
armybyrd's Avatar
armybyrd
No cats-longtubes to x-pipe and a pair of spintech mufflers. Does this sound like anything I should be worried about?
Old Mar 25, 2012 | 01:30 PM
caddyboy84's Avatar
caddyboy84
It's the metal expanding and contracting from the heat, not to worry
Old Mar 26, 2012 | 09:12 PM
Calderone's Avatar
Calderone
pretty normal
To '88 Making Noise When Off?
