Help w/ RS Window
Old Mar 25, 2012 | 12:01 PM
cqlink's Avatar
cqlink
Default Help w/ RS Window
RS window was stuck in "up" position. Pulled switch and had 12V to switch. Began collecting tools to pull door panel and checked a few threads here on how to pull panel.
Along the way, a couple of members mentioned closing door hard with switch depressed occasionally works (yeah, right. I'm NEVER that lucky).
After spending $50 first for rubber mallet (to tap door panel), K-D Tools trim puller, white lithium grease for window track, I got in car, set ign switch to accessory position, depressed window switch and closed door hard.
Window works fine. I'm now going to buy a lottery ticket!.
Anyone know what happened?
Old Mar 25, 2012 | 12:03 PM
ch@0s's Avatar
ch@0s
It was stuck.
Old Mar 25, 2012 | 06:26 PM
93Rubie's Avatar
93Rubie
Rubber mallet? I can see maybe the Trim Tools. Heck, on my 93 I pocket screw driver and #2 Phillips and I can pull the panel. With no damage I might add.
Anyway, hope it keeps working. If you do have to pull it, FYI, the hidden screw behind the door lock indicator, might want to get that one.
To Help w/ RS Window
