Torque Conerter help
Old May 17, 2002 | 03:54 PM
No Ordinary 91's Avatar
No Ordinary 91
Cruise-In III Veteran
Default Torque Conerter help
Lilred is going to be replacing her TC this weekend, and then we plan on taking her car out to Bowling Green next week, is this a poor decision? Is there a break in period for TC's? April plans on auto-xing, and drag racing while out there, any help would be greatly appreciated
Old May 17, 2002 | 03:57 PM
scorp508's Avatar
scorp508
No breakin for a TC. It "could" be a bad decision. If for some reason it doesn't want to go into lockup, that would be a very long drive to BG. You don't want to be like me and have to not be able to go because of 'something' not working when it goes back together. :(
What stall did she pick? Did she put it on the dyno to get an idea of what RPM would be most beneficial?
Old May 17, 2002 | 04:12 PM
No Ordinary 91
Default Re: (scorp508)
i believe she went with a 2800, her dyno was pretty good, torque was flat all the way across
Old May 17, 2002 | 04:24 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Torque Conerter help (No Ordinary 91)
I agree with Scorp.
You can easily test for lockup but that's a long haul with a new component just installed.
Old May 17, 2002 | 04:50 PM
No Ordinary 91
Default Re: Torque Conerter help (65Z01)
well we have my car as a back up, and it will be in tommorow so we have sunday, monday, and tuesday to check for problems.
Old May 17, 2002 | 04:51 PM
scorp508's Avatar
scorp508
Not what I meant. I mean did she pick a stall # using her dyno as a guide?
Old May 17, 2002 | 06:55 PM
cprgmr's Avatar
cprgmr
When I put the Vig in, the instructions said to do between 25-50 lockups to break in the plates. Are you going to be doing the install yourself? If you are, have you dropped the tranny before?
Old May 17, 2002 | 07:42 PM
RadPolo96's Avatar
RadPolo96
Mine seemed just fine after the install, and even gave it a little gas a few time to see the difference :D
To Torque Conerter help
