i have a 1984 coupe that has been converted to a regular carb system.Im looking to buy a
HEI distributor w/ DUI coil, cap, rotor, ICM will this distribitor fit my car,the seller says he knows for sure it will fit from 85-89 but he is not sure about 1984,does anyone know Thanks
I put an HEI in my 74 Olds Cutlass from it's stock points set-up, it'll fit. Just make sure it's for a Chevy 350 and has a vacumm advance.
When I carbed my 84, I bought an Accel blueprint distributor with vacuum advance for a small block. It'll fit any smallblock from the 50s up to the lt1.
