Security or vats problem idk. :(
Old Mar 29, 2012 | 02:50 PM
dragonwarrior88's Avatar
dragonwarrior88
Default Security or vats problem idk. :(
I have a 93 c4 auto 96xxx miles.
Here's the story one day I drove my vette and decided to leave the keys on the back of my other car. Well I took off with the keys on the car and obviously fell off.
So I ordered a key from Chevy with my vin. After trying the key the key wouldn't turn. So I decided to get a locksmith he got his key cut to turn the ignition with the #13 pellet and no crank! Fuel pump kicks in gauge lights turn on and I believe starter solenoid clicks. Security light stays lit. Wtf... So I got the Chevy key to work with a lil trimming and same thing!
I tested the key cylinder by placing the key in the ignition unplug vats harness and tested #13 throughout off/acc/and on position so the contacts are touching the pellet.
Next thing I did was made 15 resistors all within specs tried all 15 3times and nothing
Checked ccm for codes and got h51 and h53 which is ?.. I keep seeing it can be a bad ccm. Not sending a handshake to the ecu.
Old Mar 29, 2012 | 05:07 PM
WVZR-1's Avatar
WVZR-1
The h indicates history. Here are your CCM error codes:
http://tech.corvettecentral.com/2011...trouble-codes/
It's doubtful that the VATS resistance would have been included with a '93 MY inquiry BUT stranger things have happened. Did the dealer give you the key #'s and the VATS code? The code from their inquiry would not have been a "number" but a 2 letter code that needs to be converted to a number code using a chart. If your VATS code was part of the inquiry then maybe they just referenced the information incorrectly for the 2-letter to # code!
I'd start at the dealer if they supplied you with the VATS information!!
If I understand you correctly you have a key that rotates the cylinder! Correct?
Old Mar 30, 2012 | 12:18 AM
dragonwarrior88
All they asked was the vin# and said its #13 and ordered it. Cut the key didn't turn the cylinder till I had a locksmith make a key by scratch. Shaved a little off the dealer key and it turns the cylinder but both keys no crank.
Old Mar 30, 2012 | 02:50 AM
WVZR-1's Avatar
WVZR-1
Just ask the dealer to check the resistance code again. Ask the dealer for the 2 letter code that the key request response contained. When GM started key requests by VIN the resistance was included in the results by number but later changed to the 2 letter response. Yours maybe came back with the numeric response. Regardless it's the first question to ask!
It's not unusual to need to remove the sharp edges of a newly cut key to accomplish a mechanical rotation.
You "hinted" that the solenoid clicks? If the solenoid clicks I'd think it NOT VATS related! Fresh battery?
Old Mar 30, 2012 | 08:32 PM
dragonwarrior88
fresh battery. the solinod sound like its under the dash. but when i tested all 15 resistors the solinod clicked for all resistors.
Old Mar 31, 2012 | 06:38 PM
larryfs's Avatar
larryfs
and you don't have a 2nd set of keys ??????????
Old Apr 1, 2012 | 02:05 PM
dragonwarrior88
My parents lost it and gave me one key and I lost that
Old Apr 3, 2012 | 11:03 AM
senorv47's Avatar
senorv47
www.vatssucks.com
Old Apr 3, 2012 | 11:08 AM
the blur's Avatar
the blur
why does VATS suck?
in fact, it's doing its job, and is the best anti-theft device.
anyone who bypasses VATS is asking for their car to be stolen. It's a simple repair to replace a lock cylinder.
This OP above proves VATS works, and does what it is designed to.
He lost both keys, VATS WORKS !!!
To Security or vats problem idk. :(
