FUEL INJECTOR REPLACEMENT
Old May 17, 2002 | 10:38 PM
kattim1's Avatar
kattim1
Default FUEL INJECTOR REPLACEMENT
hOW DIFFICULT IS IT TO REPLACE THE FUEL INJECTORS ON A 1987 L98
Old May 17, 2002 | 10:41 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: FUEL INJECTOR REPLACEMENT (kattim1)
Not too difficult.. a couple hour job I'd say.
Old May 17, 2002 | 10:46 PM
kattim1's Avatar
kattim1
ANY WEB SITES THAT WOULD GIVE ME ANY IFO ON DOING IT?
Old May 17, 2002 | 10:52 PM
scorp508's Avatar
scorp508
Get yourself a service manual if you don't have one first. It isn't a bad job at all. :) Depressurize the fuel system, remove the plenum & runners, unbolt the fuel lines, take the 4 holddown bolts off the fuel rail, unplug each injector, disconnect the cold start valve, pop the rail off. After that it's pretty easy to replace the injectors. :)
Old May 17, 2002 | 10:57 PM
kattim1's Avatar
kattim1
Default Re: (scorp508)
tHANKS DOESN'T SOUND TOO HARD. ANY SUGGESTIONS ON WHICH BRAND TO USE OR FROM WHO
Old May 17, 2002 | 11:02 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: (kattim1)
Hurmph.. why cant you post in lowercase like everyone else??
Old May 18, 2002 | 01:50 AM
Corvette0096's Avatar
Corvette0096
Default Re: (MarkLT1)
THAT DEPENDS ON WHAT YR OF VETTE YOU HAVE. I HAVE THE SVO24 AND THEY ARE GREAT, THAT IS FOR MY SET UP.. :p:
Old May 18, 2002 | 12:50 PM
kattim1's Avatar
kattim1
Sorry did not mean to offend you.
Old May 18, 2002 | 01:08 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Thats ok.. I was in a bit of a funk yesterday.. and was kinda snappy.. :lol:
As for the injectors- the FMS are good replacements from what I have heard.. I know SpeedDemon M/S carries them for $230 for a set of 8. They are actualy rated at a lower psi, so on a vette, they will act as a little bit bigger an injector (they are rated at #24, but have heard that they act like #26 or #28).
-Mark
To FUEL INJECTOR REPLACEMENT
