Missing backup switch wiring
Old Mar 29, 2012 | 06:11 PM
TSHANNON's Avatar
TSHANNON
Default Missing backup switch wiring
The previous owner removed the wires and connector from the backup switch.Can't seem to find where he cut the wires out. My question is can I buy the connector and wires so I can add it to the main harness or just the connector?
I'm finding a number of silly things he did with the wiring when he put a push button start in and a new stereo as well as he had the cooling fan powered from the front side marker.
Thanks Tim
Old Mar 29, 2012 | 06:38 PM
LannyL81's Avatar
LannyL81
Assuming you have a 6sp trans:
If you purchase a replacement back-up switch....which are now only available as an aftermarket piece, it comes with the connector on wires. You could just cut the connetor off and wire it into the wiring harness using some small bullet type connectors.
Or I guess you could find a used wiring harness connector and wire it in and then plug the aftermarket back-up switch in.
Finding the wires could be a bit difficult to get to as they are in the harness that goes across the top of the transmission. Not exactly easy to get to.
Now if you have an auto the back-up switch is in the console. But that is all I know about it. Never owned an auto.
Good luck with it.
