Pull a valve cover problem should make itself obvious
You can use a stethescope (long wooden/metal dowel) run it along the valve cover with the other end to your ear youll know real quick where it is before pulling it off. Check to make sure your pushrods are straight too
check the exhaust gasket , i was fooled long time thinking of bad bad problems
i even swapped lifters !!! it was the exhaust gasket at cyl #8 ! and it was impossible
to view !
just call me rain man. exhaust leak #8. i know what shop im not going to anymore. i did what they did and ONLY used a stethoscope. what about using a freaking wrench??? both bolts very loose.
All better. thank you for your help
