First of all I would like to thank everyone has gotten me this far on my stock 85.........I just replaced the injectors.....well had a few tech promblems since then.............( the timing) .........I think I have got that worked out..........now when I am idling it smells like it running way to rich (burning your eye rich) ...........any IDEAS.........Thanks Bo
I've got similar issue, it's not so bad that it burns my eyes. My A.I.R. System has been deleted, I installed a new CAT. I've checked for vacuum leaks and basically replaced all the vacuum lines. When I was doing my vacuum lines I was able find a diagram on the web. I googled it, if I remember correctly it had been posted on some other forum. If you come up with a solution, let me know. I am under the impression that I'm getting the smell of unburned gas because my A.I.R. System has been deleted and the CAT is not getting hot enough.
I once had the air diverter freeze up, sending air into the manifolds all the time, makig the o2 sensor think it was lean so the computer put it into full rich. Removing the system fixed it and it smelled fine, no new problems. Was a firebird though, but shouldnt be too different.
Keep in mind that 02 sensors can also fail in ways that wont throw a trouble code. Mine had one that once warmed up put out a nearly fixed voltage in the mid .4s. Make a scanner cable, find an old laptop, and check your sensor readings.
