oil pressure.
Old May 21, 2002 | 01:28 PM
EdO87's Avatar
EdO87
Default Re: oil pressure. (Blue88)
I replaced the oil pressure sender on my 87. I removed the wiper motor, reached in, unplugged the connection, unscrewed old one; screwed new one in, put connection back on, replaced wiper motor. Check out service manual on removing wiper motor. Not difficult.
Old May 22, 2002 | 03:46 PM
VetBoy89's Avatar
VetBoy89
Default Re: oil pressure. (devilfish)
Is the part that you guys are referring to the "Fuel pressure switch and oil pressure sensor", combined in one unit?
Old May 23, 2002 | 09:46 AM
Blue88's Avatar
Blue88
Default Re: oil pressure. (VetBoy89)
The oil pressure switch is located on the drivers side of the engine just below and behind the distributor. It is about 1 1/2" in diam and is just below the oil temp switch and has only one wire running to it.
Old May 23, 2002 | 02:24 PM
VetBoy89's Avatar
VetBoy89
Default Re: oil pressure. (EdO87)
I replaced mine last night, wasn't to hard to do, kind of a PITA. I pulled the wiper motor and then I found it easiest to use locking pliers on the sensor itself. My old one was silver, the new one is black. I was showing 5 psi when the key was on and car off, now I show 2 psi. Why doesn't it go to 0 psi? :crazy: :smash:
