1988 power brake problem
Old Apr 1, 2012 | 08:55 AM
Jim 427's Avatar
Jim 427
Default 1988 power brake problem
I have a 1988 rag top with 22,000 original miles. I bought the car with 18,000 miles and obviously only drive it occasionally. As long as I've owned it the power brakes seem to need more pedal pressure than it should. It feels like it has standard non assist brakes. It does not pull to either side during braking. I have checked the booster and check valve. Both are operating properly. The vacuum applied to the booster is as it should be. There are no leaks or anything else out of the ordinary, it just takes more pressure applied to the pedal than power brakes should require. Any help would be appreciated.
Old Apr 1, 2012 | 10:09 AM
caddyboy84's Avatar
caddyboy84
There is an adjustment behind the master, it may not be properly pressing (or over pressing) the plunger on the master. I just changed my whole system and what I did was this: I used a piece of modeling clay and put it between the plunger and the master then bolted it up to specs, I then removed the master and checked the clearance, it turned out that I had to screw out the plunger a little bit. The plunger unscrews by holding the outside ring with a needlenose and unscrewing the plunger. Try this, I bet it's your problem, the assembly isn't at "full travel". The plunger on the booster should be touching the rear of the master just right, make sure your plunger isn't out too much and depressing the brakes aslo.If you feel any spring tension when you're bolting-up the master, that means the plunger is out too much, which means your brakes are being depressed already without your foot even being on the pedal. Unbolt the master and remove the caps, now rebolt it and look for bubbles, if you see bubbles, the plunger is out too much. You may just have a bad booster, but I doubt it. Give the booster a vacumm check.
Old Apr 1, 2012 | 11:26 AM
Jim 427's Avatar
Jim 427
Thanks caddyboy, but that's not it. The rod is adjusted correctly.
Old Apr 1, 2012 | 11:50 AM
caddyboy84's Avatar
caddyboy84
Check your manifold vacumm and then the booster itself. It could only be the booster or a fualty master. Bleed all four corners and check the calipers. I just remembered the ABS pump and the porportioning valve, might want to look into those things as well.
Old Apr 2, 2012 | 08:56 AM
Jim 427's Avatar
Jim 427
Vacuum booster, check valve, vacuum, calipers,.....all check out ok. Brakes still too stiff.
Old Apr 2, 2012 | 09:52 AM
caddyboy84's Avatar
caddyboy84
If you're sure everything is good, the only thing thats left is the ABS pump under the driver-side rear speaker. I'm gonna do a little research and find out about the symptoms of a bad one. Do the brakes feel the same if you disconnect the booster vacumm? This is kind of strange for a car with such low miles, the brake system is pretty straight forward. You have bled all for corners right? My manual says that it may be a good idea to chech the ABS unit and it's electrical connections, also the ABS fuse in the fuse box.
Old Apr 2, 2012 | 05:35 PM
Jim 427's Avatar
Jim 427
Apparently you are on the right track. I found this thread and they talk about "Fred Flintstone brakes". That about sums it up. From what I've gleaned from all these posts, it is a common problem for C4's, and I need to figure out how to clear codes in the computer and then go out after a rain shower and force the car's ABS to engage 2 or 3 times. Now,.....do you know how to clear these codes?
http://forums.corvetteforum.com/c4-t...n-finally.html
Old Apr 2, 2012 | 05:56 PM
caddyboy84's Avatar
caddyboy84
Well ,if you don't have a scanner you gotta disconnect the battery. I've been meaning to get an ABS cartridge for my scanner, but the books I've looked at say you'd get an ABS light. It's a pain to get at that pump, but did you check the connections to make sure its getting power? We do have hard rides, ya never know. I'd like to think that you don't need any new parts, it sounds like something stupid, like a loose plug, but you wont know till you check. Hearing your problem with this makes me feel lucky that after doing my whole system, that evrything seems good. I actually blew my master by changing the fluid. The fluid when I got the car was like syrup, when I changed it and bled it out the rear seal went, which is why its a gamble changing old fluid in anything.
Old Apr 2, 2012 | 06:07 PM
Jim 427's Avatar
Jim 427
Will just disconnecting the battery reset the codes? I just put a new battery in the car last week, so that in itself didn't do anything. I guess I'll wait for the next rain event to exercise the ABS. I'm in the Carolina's for the next 2 weeks. I'll get on it when I get back.
Old Apr 2, 2012 | 07:03 PM
caddyboy84's Avatar
caddyboy84
As far as I know the computor won't hold codes after the battery has been disconnected. I'm still thinkin you'd get an ABS light and I'm still thinkin it's the booster. But it's hard to diagnose things like this without feeling it myself.
Old Apr 2, 2012 | 08:13 PM
Jim 427's Avatar
Jim 427
The booster was the first thing that came to mind for me as well, but it is good. Did you check out that thread? My car acts just like the ones they talk about. Apparently the ABS can screw up over a period of time and can be "realigned" by forcing it to activate on wet streets. It makes sense since so many other owners were having the same problem at the time of that post.
Old Apr 2, 2012 | 09:24 PM
caddyboy84's Avatar
caddyboy84
I'm gonna read that later on, I'm very curious about this problem you're having. Can never learn enough I just thought of something, don't kill yourself with that brake test, I've never heard of that but I'm gonna ask around.
Old Apr 2, 2012 | 10:08 PM
Jim 427's Avatar
Jim 427
Can I access the ABS from inside the car? If so point me in the right direction. You said under the speaker on the driver side right? I'll check the connectors before I go "drifting".
Old Apr 2, 2012 | 11:55 PM
caddyboy84's Avatar
caddyboy84
Ya gotta take out the speaker behind the driver seat, pull up the carpet and you'll see an access panel, it's in there Sometimes ya gotta have a little patience and do some more research or reading, a lot of times I used what I learned here and kinda expanded on it by doing more research. I would hate to have someone do anything they didn't have to, so you might want to get more info before gutting out the back of the car. I've always found the guys at the dealership to be helpful in trouble shooting things for me.
Old Apr 3, 2012 | 12:03 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you pull power to reset the ECM codes you lose radio & clock presets.
I prefer to open the connector in the thin Orn wire comming from the battery + terminal as that only removes power to the ECM.
Old Apr 3, 2012 | 12:07 AM
caddyboy84's Avatar
caddyboy84
Thats true. I hate having to re-set all that crap. Thats why resetting through a scanner is so much better.
Old Apr 3, 2012 | 07:08 AM
Jim 427's Avatar
Jim 427
Guess it's a mute point at this stage since I just replaced the battery anyway. So I've got the codes cleared, now I just need to cycle the ABS. Sounds like it's a bit of a pain to get to the ABS if I don't have to. I may just do the wet street thing first and see what happens. I have a 68 tri-power with 2 pedals. The one on the right bangs your head on the back glass, and the other bangs your nose on the dash. The 88 is my wife's car and the go pedal is no slouch for what it is, but that whoa pedal sucks and always has since I've had it. I'll get it figured out eventually. As many folks that chimmened in on that other post, I'm surprised this one hasn't generated any more response from others that have had this problem. Anyone else resolved this issue?
To 1988 power brake problem
Old Sep 9, 2013 | 10:44 PM
wemory75's Avatar
wemory75
I have the same problem. Put new brake shoes and turned the rotors. You can stand on the brake pedal and the car just slows. The anti lock light came on but now has gone off. I still have bad brakes. Mechanic first words. We're booster. Sounds like that's not the problem. Mechanics here just like changing parts.
Old Sep 10, 2013 | 06:42 PM
HandsomeMike's Avatar
HandsomeMike
Same thing on my 89. Brakes require a lot of pressure to stop quick and feel a bit manual like. I am going to bleed the system in case there is air and add Hawk HPS pads. I've read that they really increased stopping performance for people like us with this problem.
Old Sep 10, 2013 | 07:42 PM
hooked073's Avatar
hooked073
Wemory75 you found a post that is over a yr old!! Chance are if you have a hard pedel that is hard to push to get the car to stop you have a booster problem
