Stalling & Low Voltage at Idle
Old May 18, 2002 | 09:51 AM
J.H.'s Avatar
J.H.
Default Stalling & Low Voltage at Idle
My 85 occassionally stalls (stops running). However, it cranks right back up and maybe OK for a while then stalls again. Each time, however, it cranks back up. Also, the voltage, when idling, oftens drops to around 11.5 volts. This is especially so when the AC and/or the headlights are on. What could be the problem?
Old May 18, 2002 | 11:30 AM
LD85's Avatar
LD85
Default Re: Stalling & Low Voltage at Idle (J.H.)
Have you replaced your O2 sensor ever, and checked the volatge on the TPS?
On my 85,, replacing the O2 sensor made an immediate improvement. Then I reset the Throttle Position Sensor and it idles now at 690-720.
Old May 18, 2002 | 11:35 AM
Corvette0096's Avatar
Corvette0096
Yes I would check and make sure you have the correct voltage and clean the throttle body at the same time.
Old May 18, 2002 | 12:10 PM
jfb's Avatar
jfb
11.5 if real, is too low. Check your battery terminal voltage and compare it with the dash voltmeter. Often the dash voltmeter reads low.
Old May 18, 2002 | 12:28 PM
BobMachus's Avatar
BobMachus
Default Re: Stalling & Low Voltage at Idle (jfb)
You could have an underdrive pulley set on your car. The voltage on mine with lights and fans drops to around 11.5 volts at idle. I have just an underdrive crank pulley. Low voltage affects injector pulse width, so that may be part of the stalling issue. Good Luck.
Old May 18, 2002 | 02:51 PM
J.H.'s Avatar
J.H.
Thanks for the replies. I did reset the idle speed and reset the TPS to .54 voltage. So far things seem better. I have not driven much since setting these items, but the voltage readings, etc. do seem better.
THANKS!!!!!!
Old May 18, 2002 | 04:06 PM
LD85's Avatar
LD85
Yeah my car with AC on etc is no less than 14.0.
To Stalling & Low Voltage at Idle
