removing the egr ?
Old May 18, 2002 | 06:02 PM
dave g's Avatar
dave g
Default removing the egr ?
i just put a new motor in the car and removed the egr and blocked it of with a plate .now when i start the car it will not idle until you warmed the car up it always seems to be surgeing at idle and it will stall . do you think it the egr our something else .
Old May 18, 2002 | 06:21 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: removing the egr ? (dave g)
If I am not mistaken, removal of the EGR usualy requires some reprogramming of the computer, which might be your problem.
-Mark
Old May 18, 2002 | 06:25 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
What year Vette?
On a L98 the EGR is not turned on at idle.
Check for air leaks, fuel pressure problem or a problem with the IAC.
Old May 18, 2002 | 06:28 PM
dave g's Avatar
dave g
its a 86 l98
To removing the egr ?
