Why do I smell gas?
Old Apr 5, 2012 | 07:21 AM
caddyboy84's Avatar
caddyboy84
Default Why do I smell gas?
I changed the injectors, the fuel filter, the regulator, the fuel pump and the smell is not comming from under the hood. I have no liquid leaks that I can see so I'm thinking it's vapor, but from where? When I changed the pump, I reused the original gasget (it seemed fine) and I never had this odor before. I don't smell anything at the gas door, it's like it's comming from under the car, I smell it when I open my door. This smell is making me a little uneasy and I know it's from something I did because I never had it before.
Old Apr 5, 2012 | 07:33 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Recheck the fuel filter, sometimes they need just a little more oomph to seat correctly.
Old Apr 5, 2012 | 07:35 AM
toptechx6's Avatar
toptechx6
I would inspect the lines to the charcoal canister, a loose or broken one will cause what you describe. Strangely it seems those vapors cause more odor than liquid fuel in my experience.
Not sure where it is located on your 88, it is buried up under the right quarter panel on my 93, hope that helps.
Old Apr 5, 2012 | 08:10 AM
caddyboy84's Avatar
caddyboy84
I thought of that, but mine is under the hood and I have no odor under the hood (P.S. does that canister have a filter?) anyway...I was thinking the fuel filter also, but wouldn't I get a drip...drip...drip? I mean it's pretty close to the floor, I would think I'd see something on the floor. But it seems I'm getting the smell more on the driver side. I'm a little perplexed and nervous, I don't want a fireafter all this work, I"D BE PISSED!!
Old Apr 5, 2012 | 08:33 AM
toptechx6's Avatar
toptechx6
Even if your canister is in the front there has to be a line going to the fuel tank, that is where it collects the fuel vapor to be burned. If that line pulled apart or broke when you were doing the fuel filter or the pump, it could be the cause.
Old Apr 5, 2012 | 08:41 AM
caddyboy84's Avatar
caddyboy84
Thanks, I'm gonna go over everything because that smell really scares the crap out of me. I've seen alot of cars burned to a melted blob because of things like this
Old Apr 5, 2012 | 08:46 AM
toptechx6's Avatar
toptechx6
No argument from me, I worked in the car business my entire life and never lost a healthy respect for the smell of fuel. Hope you locate the problem.
Old Apr 5, 2012 | 08:54 AM
caddyboy84's Avatar
caddyboy84
Old Apr 5, 2012 | 10:52 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Remove the line that goes from your fuel tank to the cannister and plug it at the tank. Let it air out for a day and then go back to see if you can still detect an odor.
I had a small leak when I replaced injectors too. I found that I had nicked up one of the injector O rings when I put it back together. Pain in the arze to replace it but I too did not want a fire to ruin my day/month/year/life.
Old Apr 5, 2012 | 11:00 AM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Just to state the obvious, don't keep the car in an enclosed area until you've got this figured out. It just takes a spark......
Good luck, and let us know the outcome.
Old Apr 5, 2012 | 08:50 PM
caddyboy84's Avatar
caddyboy84
Thanks, good lookin out I'm actually gonna have to follow my nose on this one. I am gonna check that filter again, I hope it isn't that, because on a Vert it's a bitch. It took me 2 hours to change that filter on the floor. The dreaded X brace, "nuff said".
Old Apr 5, 2012 | 11:44 PM
Cliff Harris's Avatar
Cliff Harris
Your problem might be on the other side of the car from the fuel filter. Just in front of the rear tire on the driver's side is a rubber hose that couples the front and rear steel lines for the vapor cannister. Check that guy out. Here's a pic of my '86 (yours might be different):
Old Apr 6, 2012 | 09:12 AM
caddyboy84's Avatar
caddyboy84
THANKS I'm gonna check that out, I see that little hose there. It might be dry rotted, everything else plastic and rubber is brittle on this car, why not that. I know I did all my work correctly and didn't break anything but whenever I fix or up-grade anything something else happens. It's just the Big Man "getting my nose".
Old Apr 6, 2012 | 11:53 AM
mcm95403's Avatar
mcm95403
I had the same problem recently. turned out in my case that it was the seal on the gas cap. Less than $10 for a new one at O'Reilly's and the problem was solved.
Old Apr 6, 2012 | 02:26 PM
slickfx3's Avatar
slickfx3
if when you remove your gas cap and it is pressurized and hiss out fumes ( which you might be smelling), your canister valve may be bad, you can plug the vacumm source to it and bypass it temporarily.
Old Apr 6, 2012 | 02:42 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
If you can't find it, find someone with a smoke machine. I have one and its very handy for finding these kind of leaks.
Old Apr 6, 2012 | 03:25 PM
caddyboy84's Avatar
caddyboy84
Your talking about the charcoal canister at the front drivers side, correct?
To Why do I smell gas?
Old Apr 6, 2012 | 03:29 PM
caddyboy84's Avatar
caddyboy84
Looking at your picture, I see that you should remove the stress thats being applied to that little hose. Bend those metal lines together a little bit, you can see that hose is being stressed and pulled apart.
Old Apr 6, 2012 | 05:59 PM
slickfx3's Avatar
slickfx3
yes it's in the front below the headlight system, take the valve off and run a length, I use high grade motorcycle fuel line, but any automotive fuel line will do and jump over the valve from canister to fuel line and I suppose the valve if left on will not have any leaks, but if its broke I would not chance it and use a nipple cap and you have a direct vent to the canister from the fuel tank, the canister will still need the ecm to activate the solenoid to allow the canister to vent into the intake steam on start up.
but you have took out the initial potential blockage as a start to diagnose.
should not have any problem driving like that, do this only if you are having high pressure in the gas tank evidenced by fume rushing out of the tank when you go to fill with gas, if not your valve should not be the culprit
Old Apr 6, 2012 | 08:55 PM
caddyboy84's Avatar
caddyboy84
Thanks everybody I got some good input and starting points.
