Found this inside my door????
Apr 5, 2012 | 01:55 PM
I'm prepping an 88 coupe for a repaint, and started taking the doors apart to pull the mirrors and body moldings.
I found this rattling around in the bottom of the drivers side door, and I can't seam to find anything on the passenger side that looks like it.
Anyone have a clue what it is?
I'm stumped, the window works fine, locks all work, etc.
Apr 5, 2012 | 02:02 PM
hey ive been looking for that. I knew i left it somewhere
Apr 5, 2012 | 02:05 PM
Maybe some type of door shim?
Apr 5, 2012 | 02:49 PM
Oh crap !! The door is going to fall off now.
Apr 5, 2012 | 03:13 PM
It was down near the lock and door handle end.
Thought maybe it was some kind of blocking plate to stop someone from fishing the door lock, but I don't see it on the other side.
It's odd that it has only one hole in it.
Apr 5, 2012 | 03:20 PM
Quote:
Originally Posted by
SuperL98
I have been in many a door panel I have not been in mine. I have seen similar covers and I believe you are correct.. it looks like it covers the door handle. Does it fit there?
Apr 5, 2012 | 06:22 PM
Just chuck it. Your door worked with it nestled at the bottom. Your car will be lighter and faster.
Apr 5, 2012 | 07:04 PM
Could it be a fitment gauge used on the assembly line?
Apr 5, 2012 | 07:41 PM
Got another chance to look at it after I got cleaned up.
It has a part number on it.
1311
10082829 LH
I'm not too concerned about it, just a mystery that I don't see anything inside the other door that looks like it.
BTW - I hate jamming my arm up into these doors.
You have to be Gumby or something to reach anything.
Apr 5, 2012 | 07:48 PM
Apr 5, 2012 | 07:52 PM
Apr 5, 2012 | 08:26 PM
i have a kit that was issued for the loose door panel fix on the 84-87 corvette. there were four brackets that installed at the top inside edge of the door panels. the brackets would slide over the inner metal frame of the door.
Apr 5, 2012 | 08:31 PM
So we just accidentally found how to fix our panels?
Apr 6, 2012 | 05:48 AM
JackDidley
Holy crap... just saw the shipping to Australia check the screen shot
I mean i got a 91 steering wheel with airbag shipped 20 dollars less than that .
Glad i don't need it and i ain't pulling my door trim off to look for it !!!!!
Apr 6, 2012 | 08:13 AM
SuperL98.
Any chance you can post some measurements of the bracket so we can make them, looks easy enough to make.
Thanks!
Apr 6, 2012 | 09:44 AM
PM me your email and i can send you some PDF info that is the Bloomington Gold Restoration Workshop, 22 page PDF for the C4 Door R&R
Anybody else can PM me as well, it may or may not be helpful to you, but still good to keep around
Apr 6, 2012 | 02:39 PM
thedesertvette
SuperL98.
Thanks!
Just a quick sketch measured with calipers.
Best I can do.
Keep in mind that the RH side would bend the other way.
LD85
I will PM you, taking these doors apart is a real pain in the A.
thanks
Apr 6, 2012 | 03:49 PM
WOW - great job on the measurements! Thanks SuperL98!!!
Apr 6, 2012 | 10:42 PM
SuperL98
Best I can do.
LD85
thanks
Niiice! Do you & Agent 86 hang out together?
Apr 7, 2012 | 01:16 AM
St. Jude Donor '08-'09
gerardvg
$33.45 to Canada.. WTF
